How to get more boost
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
Do anyone know how to hook up the two ports on a hks wastgate the one on the side and the one on top to a mbc.i have the hallman (hbc).from what someone told me was I can hook up the two ports to get my wastgate to stay closed stronger to build more boost with out changing the spring on the hks.when I use the side port on hks and run it to the hbc that is turned all the way in I get 25psi .so is it possible to run both ports with a mbc.
After a quick search it seems that you only use the bottom nipple and run the mbc through that line, not 100% positive, just read what other's have done.
Edit: Another post says to run the bottom one just to a boost source and the top to another boost source with the mbc.
Not sure, but you can try both and see if they work.
