How to check balance shaft bearings? + 2g rod bolt torque specs?
Hazard
82
May 7, 2003
Swanton, Ohio
1) I was just wondering what the procedure was for checking balance shaft bearings with the engine still in the car
2) Also, if the (front?) balance shaft bearing is bad (the one that the balance belt goes around) could i just remove the belt for now and would i be ok?
3) I also do not know the torque specs for the 2g rod caps. This is my first 2g and i dont have the manual yet.
4) What needs removed to drop the oil pan on a 2g AWD? I know on my 1gFWD i just have to bascically drop a crossmember and downpipe.
My problem is basically i have a knock that is steady around 2500-3000 rpms then goes away. the car idles fine with no noise. I'm trying to drop the pan today to get a better look at things but i have to pull the engine out of my 1g first, so i figured i'd get some little questions out of the way that i was unsure of.
cmon some of these could be answered by anyone with a manual, i should have one but i just got this car a couple days ago and have never owned a 2g :cry:
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
