How to bead your own intercooler pipes.
I've read a bunch of threads about ebay intercoolers and pipes, beaded, unbeaded, glueing them, scoring the pipes so they grip the silicone couplers, etc. The main complaint people had, was the unbeaded pipes coming undone.
I chose a 27"x 7" X 2.5" FMIC kit with a starter piping kit (2.5" pipes), and a knockoff blowoff valve for only $175.
It came with T-clamps, a bunch of couplers and various pieces of pipe.
Pipe with no beads!!!
Since it's a Colt I figured I would never find a direct fit FMIC kit anyways, so I was ready for some cut and fit. Who needs beaded pipe if you're going to cut it up anyways right?
Here's the "how to" section of this post: First you'll need some materials you will probably be able to find around your garage.
1) A large thick washer.
2) A saddle from a muffler clamp.
3) A large pair of vise grips that you don't want to use as vise grips anymore.
4) A welder or someone who can do a two minute welding job for you.
Do a little bit of simple gringing cutting and welding until you have something that looks like this:
I took the washer to the bench grinder first, and rounded the "business edge" of it so it wouldn't gouge the pipe inside. The rest is pretty self explanitory by looking at the pics.
When you place your saddle into the vise grip, make sure it's square to the washer, and try to grind the jaw of the vise grip in a manner that allows you to bottom out the pipe in the jaw for a quick accurate bead placement. Too close to the pivot of the pliers, and your bead will be too near the edge. (if that's possible) Too far, and you won't have much leverage. (helpful when working with steel pipes)
Now you have a fully adjustable pipe beading tool that works on steel or aluminum piping. You can turn the adjuster bolt to select how deep of a bead you want, and I even was able to use it to flange an exhaust pipe by simply not sliding it onto the tool all the way.
I used a 2.5" muffler clamp because thats what size my IC pipe was, but it worked fine on the 2" steel J-pipe I fabricated, and was great for flaring the 2.5" up to 3" pipe during fabrication of my exhaust downpipe.
Now I have pipes/intercooler in the car, I have a new tool, and one more reason to get that turbo engine off the stand, and into my car.
Dig the N/A frontpipe. LOL
So there it is, I hope it helps someone. I gotta go get some sleep.
Later ;)
  • For sale 1g 1G Eprom ECU
    1G Eprom ECU $185 + shipping & paypal fees* great for someone with a 1G or GVR4 who wants to...
  • For sale 1g 1G Ortiz Center Vent Dual Gauge Pod ( discontinued )
    1G Ortiz Center Vent Gauge Pod $100 + shipping & paypal fees* long discontinued * gauges are...
  • For sale 1g 1GA Clear Corner Light Set
    1GA Clear Corner Light Set $65 + shipping & paypal fees* all mounting tabs are intactYou...
  • For sale 1g 1GA Talon Grill ( Great Condition )
    1GA Talon Grill $55 + shipping & paypal fees* Great Condition !You must be registered to see...
  • For sale 2g 2G OEM Door Handle Set ( includes seals )
    2G OEM Door Handle Set $55 + shipping & paypal fees* includes both seals* found a flaw on...
