dacowgod
Supporting Vendor
- 451
- 280
- Feb 3, 2006
Morgantown,
West Virginia
I finally got the new"er" engine put in my car and have been playing around with the boost and I get a spike to 9 and levels off at 8. It spools up to this very fast like 2500 RPM.. but this is the max boost regardless whether the BCS is hooked up a MBC is hooked up or nothing is on the actuator at all. I put pressure to the actuator and it seems to function like it should and I replaced the UICP with a Dave Brode special and have a 1g bov mounted to it because that was the only real leak i was noticing when I did the Boost Leak test. other than the Idle screw but I havent got a new O ring to replace that, But i would not think it would be leaking so much boost that i cant go pass 9. So i've come to think maybe the flapper in the turbo is being blown open at 8-9 .. or something else is wrong with the turbo. The flapper is not stuck but it is very loose and sloppy without the actuator hooked up. I dont know if it is supposed to be springy and hold any pressure on its own or if its just that easy to move and relies on the pressure from the actuator to keep it closed. Oh yeah... Also already checked the Timing...its perfect... Can any body throw me out any more ideas? Thanks in advance
