How much to drill out oil feed restrictor?
LookDadNoBdyKit
237
Jan 2, 2005
San Diego, CA, California
I am using a -4AN SS feed line and am having problems with oil blowing past exhaust seal, so I got an SBR restrictor to try out. This restrictor is meant for Ball Bearing GT series turbos.
I am running a PTE SCM 50.
The restrictor is clearly too small for a standard bearing turbo, so Im wondering what it should be drilled out to? Some people say .078 and others say .080. Will it make any difference? What should I drill the restrictor out to?
Ended up drilling to .078. I will let you guys know if my smoking turbo issues go away after this.
if not i have a setup that uses nitrous jets if you want it.
