How much lag?
konigtalon
40
Jan 5, 2006
morehead, Kentucky
Ok guy's with everything said and done I have all my mods installed except form my intake and fuel pump and injectors. What I have installed is the evo111 16g, turbo fmic, wide band, findanza flywheel, light weight craqnd pulley, 2.5 full exhaust. My question is wether or not my turbo is spooling up as quickly as it should I have the boost set at 12psi It starts at roughly around 2200 rpms and hits full boost at 3500 in third gear starting from 3000 rpms. I would like to know some input from people that are experienced with these cars since im a newbie. Also how much boost would be safe on the evo11 with 680cc injectors with good air fuels and a good tune on the stock engine, engine is freshly rebuilt with the balance shafts removed. Thanks, Dewayne
First request, please update your profile to include this car.
This sounds about like the GVR4 we have in the shop right now, and it is a little quicker than my 18G was before the supercharger. I think you are good 2 go.
I wouldn't worry too much about your intake, as the stock one flows well past what you are doing here, but 300 whp+ is easily in sight. Areyou planning on doing the fuel pump rewire? I think there is more to be gained there than the pump itself.
What's your AFR look like under full power?
Yeah im planning on doing the rewire pump idea and also my air fuels are around 11.7 t0 12 under full boost sne time it hit 10 but that is really rare. Thanks
