how many people got the apexi TT penstyle?
ExoticTSI
Feb 29, 2004
central jersey, New Jersey
i was wondering if the 02 voltage and a/f ratio gauge that it has built in is accurate or not Thanx.
mine's off by .02 on the 02 and .4v on the volt display. properly grounded as per the instructions.
The a/f ratio isn't too dependable on the apex turbo timers. It is only a calculation from the stock o2 sensor voltage. So the a/f is only good as the stock o2 which isn't that great. On top of that, the voltage reading in the unit has a filteration, so the response time isn't very fast. It takes a second before the voltage change is registered. (autometer a/f o2 voltage reads faster).
Honestly, you shouldn't be depending your tuning too much on this. It will help to you get big injectors somewhat tuned, but you really need a wideband to tune
