420A How in the hell do I remove my engine harness?
eziomandude
217
3
Mar 23, 2016
Dale, Texas
I have everything undone I think. Well. In the engine bay that I can see with my eyes. Right now I'm stuck on the sensor by the transmission under the fusebox and the wires on the side where the power steering reservoir is.
Well. I tried to get the fender off. I found out because this is my first car. Apparently the harness is ran into the interior. I can't figure out how to get it all out if you have any ideas please let me know.
The RS and GS models (420a) of the eclipse had a combined harness, I don't recall if there is a junction connector in under the dash that you can undo. I would just cover it with newspaper and tape it up so you can clean/paint around it.
There's a couple good n/a 2g guys on here, but I can't recall they're screen names.
I'm doing it because I want a "Showcar". But a street showcar if that makes sense. And there are somethings I'm not doing. Since my car's apart anyway and it'll be getting restored might as well do everything.
Does the car have ABS? If not then the harness passes through the fire wall (as I’m sure you can see) and has connections behind the radio.
The rest passes through the driver’s side fender with connections near the interior fuse panel.
If it does have ABS, then the harness also passes through the passenger side harness into the interior with the abs module near the passengers feet.
Download the applicable manual here for electrical. It has everything you need.
http://codsm.org/forums/showthread.php?t=3472
