How heavy is dynamat?
Sayajin
135
Jan 11, 2003
Snellville, Georgia
Hey guys. I was getting ready to dynamat my entire car out for my sound system when I picked up the box of dynamat and realized that its heavy as hell! I was planning on setting up my system so I can remove it whenever I go to the track, but you cant exactly remove dynamat and put it back on and what not.
So my question to you guys is about how much does dynamat weigh? I mean I dont want to add another 40 pounds to my car and then go do weight reduction. Do most of you guys with a system have your car dynamated? Or do you just leave it alone? Or do you just dynamat out your trunk and leave the rest alone?
Thanks a lot for the help guys!
-Sayajin
well if it is forty lbs, it is 40 lbs. but this is what you need to consider:
Every 100lbs = .1 sec in the quarter
so in theory, if you run a 14.2, then you remove 1000 lbs, theoretically your new time will be a 13.2
so by adding forty pounds you will be .04 seconds slower than before:thumb:
good luck
dynamat doesnt weigh enough to make a difference in you times....it is just really heavy when it is all rolled together in the package. Plus its not 40 pounds heavy anyway...maybe 15 or so...
-james
yeah, not that much of a difference. i was just using the 40lb thing as an example. so 15 lbs = .015 seconds slower. not a measurable difference anyway
u need to decide if u want good sound and need lots of dynamt, get ready for a big weight gain, if u want a performance car, forget sound, simple as that
