How far, hp wise, can a 2g Tb go??
highintenzity4
221
Apr 30, 2004
Mission, Texas
Hey guys well I wanted to know when a 2g tb would start being a restriction? And how much of a restriction can it be? Im running a 60-1 setup with 272, magnus 2g intake manifold, dsmlink, etc... Also for the 450hp plus range is the adfx fmic alright? Havent really seen big hp numbers with adfx owners? :dsm:
It sounds like the TB is already a restriction for you. If your intercooler piping / throttle body elbow is bigger than your 52mm throttle body then you should upgrade.
You could get a 60mm 91-94 throttle body if it matches your piping, or you could go bigger but the other options are usually more epxensive & not as easy to install (mustang TB, etc...)
Don't know anything about ADFX though...
