how far can you push stock injectors?
95GST2841
114
Feb 11, 2006
Palm Harbor, Florida
how far can you push the stock fuel system?
I want to have a 14b at like 16lbs here pretty soon.
just full exhaust & intake with a u/d pulley
will the stock fuel system support this?
I always suggest going bigger than you need for fuel systems, but if are on a budget or something the stock injectors will be enough for 16psi. However you will have to upgrade your fuel pump because the stock is only good to around 13psi. A 190 will be sufficent for this setup. I would suggest though if you plan to ever upgrade to a larger turbo i would get a 255 and an fpr. Then again a walbro pump is only 95 dollars so its not like it would be the end of the world if you changed your mind.
