ECMlink how does this timing map look
By any chance have a full log? That may help a little more. Are you seeing any knock under load? How much boost are you pushing? Timing seems a high at idle and a little low under loads in the upper rpm. I would download a 2g map and start there maybe.
From my experience, I only had to step down the top end of the RPM to about 14* under load. Also running 10.5-1 on pump gas to get any sort of timing.
Honestly? Horrible. All the off boost its just very far off from stock and doesnt make a lot of sense... and in the boost and high load areas its pretty flat. Rules of a timing tables are-
Make everything linear and go up with RPM and down with Load increase-this one goes up, then down, then up?
Smooth transitions and no big jumps between neighboring cells. On spool up @4000 youd get a jump of 8 (24-16) no bueno. I would get a 1g or 2g timing table (depending on compression) use it for everything below 1.2 load, and just work on the high load areas above that according to knock.
thanks for all your reply guys.but I been change that timing map.check out my other post to see if u guys can help with it.thanks
