How do you remove 1g side vents
68442
639
5
Oct 14, 2007
Des Moines, Iowa
How do you remove the side vents behind the door? They seem to have a pop type rivet holding the louvers and screws behind them. I don't want to break them trying to pry them off.
If you do have pop rivets on yours, they've been replaced by a lazy shop. The rivets would have to be drilled off. To drill pop rivets, use high speed from the top with a fresh bit. You have to try and cut through the rim of the head before the shank works loose and starts to spin. They can be a complete bi*** for something so small.
Thanks for the tips. The outer part has some sort of rivet, the louvers are bolted in still. If I wasn't worried about the paint matching I would tape over them:shhh:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
