How do you get OEM fuel line in????
Black98Gst2
Mar 1, 2004
marlboro, New Jersey
I have a 98 Gs-t. I recently twisted my fuel line to its demise when I was replacing the fuel filter. I bought an oem filter, and an oem line to replace the one I broke. Its the line going from the fuel pump to the bottom of the filter. It took a while to get the old one out because of the angle, but it seems impossible to get the other one in. Between the bends in the line and the lack of space between the fire wall and the other metal, I dont see any way to do this. Any suggestions? Or can you direct me to where I can get a steel braided fuel line that would bolt right up to the stock fuel filter? Thanks
start the threads with your fingers, then go to a "line wrench" of the appropriate size.
I hate removing/replacing the stock fuel filter.
Its also easiest to remove anything that will allow you more accessibility to where you are working.
Best of luck.
What is the stock AN size for the filter. I went to the slowboy site and only saw the kit for the 1g. Can I use the 1g too? Or should I buy it buy the foot and buy fittings that are stock size?
