how do you build e16g tdo5 feed lines?
Mellon
88
Apr 30, 2004
Memphis, Tennessee
hey guys I've done some searching and found bit and pieces of info but not enough.
I have a 91 dodge stealth TT and want to run a new feed line for my rear turbo.. currently it's a hacked up job that leaks. how do you build e16g tdo5 feed lines?
from what I gather the thread at the turbo is 12x1.25mm right? and the SS braided hose needs to be -4AN correct?. I think the fitting at my block needs to be 10x1.25mm
if that's correct, which pieces will I need to buy and where can I get them?
thanks a ton in advance.. I've got to do something about this, I'm afraid I'm going to lose the hose I have and start spewing oil potentially wrecking the turbos or engine.
