how do u spot a real MHI turbo
The easiest quick way to know is to see if it has a name plate like this one, if it does then it is an ebay 16g.
This is how a real one looks
The second way is to look at the wastegate actuator, if it is straight and adjustable then it is from ebay.
If it is curve and a single piece then it is probably genuine.
This question has been asked a few times before though so a search would yield more examples.
Bonus information: The way to tell a small or big 16g from an evo3 16g is to check the turbine housing. A small or big 16g will have a nearly square flange whereas a big 16g turbine housing cuts back in around the bolts.
Small/big 16g
Evo3 16g
The way to tell a 14b from a 16g is to look into the compressor inlet, if it has alternating blades it is a 16g if it has every blade the same then it is a 14b.
16g
14b
Many people mistakenly state that there is no external difference between a 14b and all of the 16g variants, while very close to true a trained eye can spot the differences immediately and identify each turbo. The only turbos that are not identifiable without pulling them apart or checking the part number are the small and big 16g.
  • Wanted 6 bolt NT water pipe
    • chrisman287
