General how do i remove fuel cut from E931 with tunerpro ?
v8killer
371
5
Oct 4, 2002
harlan, Kentucky
i have tunerpro rt with an ostrich and i am wanting to remove fuel, how do i go about doing that !
If you have the right definition file there should be a slider for fuel cut, but I forget what number to set it at (can't check right now b/c I'm not at home). I used the hex editor in Tuner Pro to manually enter the code for fuel cut (hex editor us under tools->advanced I think). Go here to get the necessary code for fuel cut (among other things):
hwnd.org - 1G DSM EPROM Editing
(save the info from this site while you can. the site is gone but it's backed up on the wayback machine at archive.org...for now)
You can then reference what the slider is set to and compare it to the stock bin (remember to "save as" so that you can always go back to the stock bin!!!)
Manually entering the code w/ the hex editor works for any of the other features like maf compensation, knock gauge, anti-lag, etc etc etc.
