General TunerPro E931 stutterbox activation
Bricktop
281
3
Aug 24, 2009
Corydon, Indiana
Anyone know how it activates? does the clutch need to be depressed? I'm trying to figure out how to make this work on an Automatic. Right now it activates at the set rpm, moving or not. Could I wire the brake switch into pin 104 to activate it only when the brakes are depressed?
You can set it up to be activated off the wire or the vss. Are you running E931 or E932 code? The auto has some weird shit in it. I believe you can run the E931 5 speed code with no issues. I would do that and use the simple stutterbox, off the vss. I don't think there is much need for the timing retard, as the motor has to make power just to get up on the stall. I suppose it might make more boost if you antilagged the sutterbox, but I doubt you'll need it.
do this: First Generation DSM EPROM Editing
I'm running the E931 code. How would you run the stutter off the wire? From my understanding, The NLTS runs off the clutch and activates when pin 104 sees ground. I would rather run it off the wire. I have heard other guys who run it off the VSS get 1 more good pop, messing up the 60ft.
