How do I post an EvoScan Log?
I already answered this for you, but I will post it up here so if someone else reads it.
When you are done with your log with Evo Scan go to start playback.
In the box that opens up chose the log you want, right click on it, and select open with, then chose Excel. "must have office installed on the PC, or use Open Office"
Once it is opened in Excel do any editing you want to it, and save as webpage.
Now with the Excel document saved on your computer as a web page, right click on that and select open with "Notepad"
Now you will see a bunch of numbers and letters that look nothing like your log... GOOD!
Go to "edit" and select all, once all is highlighted, right click and select copy.
Now you go to a box, just like I am typing in, and type and paste what you copied in between the first code box and the second.
You should get this as results.
Code:
<html xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:x="urn:schemas-microsoft-com:office:excel"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Excel.Sheet>
<meta name=Generator content="Microsoft Excel 11">
<link rel=File-List href="Book1_files/filelist.xml">
<link rel=Edit-Time-Data href="Book1_files/editdata.mso">
<link rel=OLE-Object-Data href="Book1_files/oledata.mso">
<!--[if gte mso 9]><xml>
 <o:DocumentProperties>
  <o:Author> </o:Author>
  <o:LastAuthor> </o:LastAuthor>
  <o:Created>2009-03-24T03:04:14Z</o:Created>
  <o:LastSaved>2009-03-24T03:06:59Z</o:LastSaved>
  <o:Version>11.5606</o:Version>
 </o:DocumentProperties>
</xml><![endif]-->
<style>
<!--table
	{mso-displayed-decimal-separator:"\.";
	mso-displayed-thousand-separator:"\,";}
@page
	{margin:1.0in .75in 1.0in .75in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;}
tr
	{mso-height-source:auto;}
col
	{mso-width-source:auto;}
br
	{mso-data-placement:same-cell;}
.style0
	{mso-number-format:General;
	text-align:general;
	vertical-align:bottom;
	white-space:nowrap;
	mso-rotate:0;
	mso-background-source:auto;
	mso-pattern:auto;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	text-decoration:none;
	font-family:Arial;
	mso-generic-font-family:auto;
	mso-font-charset:0;
	border:none;
	mso-protection:locked visible;
	mso-style-name:Normal;
	mso-style-id:0;}
td
	{mso-style-parent:style0;
	padding-top:1px;
	padding-right:1px;
	padding-left:1px;
	mso-ignore:padding;
	color:windowtext;
	font-size:10.0pt;
	font-weight:400;
	font-style:normal;
	font-family:Arial;
	mso-font-charset:0;
	text-align:general;
	border:none;
	mso-pattern:auto;
	white-space:nowrap;
	mso-rotate:0;}
.xl24
	border:.5pt solid windowtext;}
</style>
 <x:ExcelWorkbook>
  <x:ExcelWorksheets>
   <x:ExcelWorksheet>
    <x:Name>Sheet1</x:Name>
    <x:WorksheetOptions>
     <x:Selected/>
     <x:Panes>
      <x:Pane>
       <x:Number>3</x:Number>
       <x:ActiveRow>7</x:ActiveRow>
       <x:ActiveCol>3</x:ActiveCol>
       <x:RangeSelection>$A$1:$D$8</x:RangeSelection>
      </x:Pane>
     </x:Panes>
     <x:ProtectContents>False</x:ProtectContents>
     <x:ProtectObjects>False</x:ProtectObjects>
     <x:ProtectScenarios>False</x:ProtectScenarios>
    </x:WorksheetOptions>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet2</x:Name>
   </x:ExcelWorksheet>
   <x:ExcelWorksheet>
    <x:Name>Sheet3</x:Name>
   </x:ExcelWorksheet>
  </x:ExcelWorksheets>
  <x:WindowHeight>9720</x:WindowHeight>
  <x:WindowWidth>15195</x:WindowWidth>
  <x:WindowTopX>480</x:WindowTopX>
  <x:WindowTopY>15</x:WindowTopY>
  <x:ProtectStructure>False</x:ProtectStructure>
  <x:ProtectWindows>False</x:ProtectWindows>
 </x:ExcelWorkbook>
</xml><![endif]-->
</head>
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=375 style='border-collapse:
 collapse;table-layout:fixed;width:282pt'>
 <col width=93 style='mso-width-source:userset;mso-width-alt:3401;width:70pt'>
 <col width=64 span=2 style='width:48pt'>
 <col width=154 style='mso-width-source:userset;mso-width-alt:5632;width:116pt'>
 <tr height=17 style='height:12.75pt'>
  <td height=17 class=xl24 width=93 style='height:12.75pt;width:70pt'>TIMING</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>O2</td>
  <td class=xl24 width=64 style='border-left:none;width:48pt'>TPS</td>
  <td class=xl24 width=154 style='border-left:none;width:116pt'>INJECTOR DUTY
  CYCLE</td>
 </tr>
  <td height=17 class=xl24 style='height:12.75pt;border-top:none'>&nbsp;</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>0.92</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>100</td>
  <td class=xl24 align=right style='border-top:none;border-left:none' x:num>80</td>
 </tr>
  <td height=17 class=xl24 align=right style='height:12.75pt;border-top:none'
  x:num>7</td>
 </tr>
  x:num>7</td>
 </tr>
  x:num>7</td>
 </tr>
  x:num>7</td>
 </tr>
  x:num>7</td>
 </tr>
  x:num>7</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=93 style='width:70pt'></td>
  <td width=64 style='width:48pt'></td>
  <td width=154 style='width:116pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
There you go enjoy posting pretty looking logs!!:thumb:
