How do I get this to work??
razrman8
1,435
25
Jul 7, 2010
Troy, Missouri
Okay. I think I might go about putting my e316g in tomoro to see if it solves my problem. Now, on my ss feed line I have the fitting pictured below on the end that goes into the oil housing by the filter. How do I get this to work on there? Do they make some sort of adapter or something?
<a href="http://www.flickr.com/photos/50007640@N06/5305186965/" title="IMAG0259 by keenanwillis, on Flickr"><img src="http://farm6.static.flickr.com/5127/5305186965_cf2f77f803.jpg" width="299" height="500" alt="IMAG0259" /></a>
you will have to get a fitting that screws to your braided line and threads into the filter housing. the fitting you have on there uses a banjo bolt usually off the head. i would just feed it from the head you will get alot of pressure from the oil filter housing unless you use a restrictor fitting.
You can attempt to get the proper second piece of the banjo bolt and screw it into your oil filter housing..which..would be silly. Or you can get the proper feed line for feeding from the oil filter housing (what I would do) or you can feed from the head, which you'll need the other part of the banjo bolt for anyway.
