exile
- 281
- 4
- Aug 8, 2004
Westminster,
Maryland
I am in the proccess of troubleshooting my uncontrolable boost. I am running a evo3 16g with the actuator that came with it. I tried using two MBCs.. one was an eBay controller that at lowest setting would start opening at about 10psi (I can tell because of the o2 dump) but wouldn't open all of the way until 20+psi. I ordered a Joe-P MBC from a trader and it's unscrewed ALL of the way and I'm not seeing ANY sign of it controlling my boost.
I was curious, before I try it.. I don't see why it wouldn't work but couldn't I techically connect my air compressor to the pressure source for my MBC and set the pounds to 10psi and see the wastegate start to open? Couldn't we adjust our boost that way as well? If it won't work please explain to me why because I thought it was a 'dumb' system it worked as long as it 'seen' pressure.
I just want to rule out my wastegate, it's the "stock" MHI wastegate and I think the spring inside maybe set higher? I should be able to take the actuator off of my t-25 and use that correct? I KNOW that one works great.
If I can't test it that way, what other way could I test it?
I've been driving this beast for 4 weeks without a MBC and I'm going to blow my engine if I don't get this fixed.
). So I know the flapper opens freely*
