How big of a dry shot? Please Help
NeDSM
37
Feb 18, 2004
Lincoln, Nebraska
I just installed a ZEX dry nitrous kit and was wondering what i need to do, my mods are: Walbro 255 high pressure, 3" cat-back, 3" Intake, Adjustable fpr, 2.5" UICP, 3" GM blow thru maf, Maft, pocketlogger, boost and a/f gauge. My question is, i usually run 15 psi, is it ok to leave it at 15 psi and run a 55 shot without retarding the timing? or do i need to lower boost? or is their anything else i need to do? please help, sorry for the new-b nitrous question
Sounds like you are off to a good start. Run a set of BPR7's gapped to .028. You should be able to leave your boost at 15 with stock timing. Make a third gear pass on the highway with a friend reading timing and knock. If the car knocks more than a few counts I would pull timing or try using a higher octane. Timing advance should be 18-20. It would also be wise to make a nitrous pass in 3rd gear and then pull the plugs and examine them. There is alot you can learn about how your motor is running by the condition of the plug (do a google search and you should be able to find pics so you know what you are looking for). Look into more exhaust mods next. Definately a 3'' downpipe and testpipe and then get a tubular 02housing and ported 2gmani.
Noslaser had alot of success with dry kits on the 4G63. You can attempt to contact him or search this site and dsmtalk for his words of wisdom. And don't forget to keep us updated!
the BPR7's say there copper on the parts catalog on the site, but every place i went there iridium. get the BKR7's, there the colder copper ones i got.
i would run some 110 and you should be fine, but you should also spend the extra moeny to get a fuel sylinoid and go wet alot better:) and your boost will be fine, cuz when you squeeze it goes to about 17 or 18 if you have it set at 15 at least on a wet kit but a dry kit maybe different.
yeah, you definitely dont want iridium or platinum, get the BKR7E-11 its the same as the BKR7E, just the V series with V-Power to prevent squelching
:confused: whats squelching?
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
  • For sale 4G63 2g/1g Parts
    2g 1g parts
    • rEclipserGST
  • For sale Walbro 255 for 2g
    Selling a new walbro 255 with install kit for a 2g. Prefer zelle for payment but can do paypal.
    • tyvo98gsx
  • For sale OEM EVO 9 Injectors
    Selling a set of OEM pink top 560cc Evo 9 injectors. Had no issues with these and they have been...
    • tyvo98gsx
