Hose Question
sccrAdidas15
377
Aug 17, 2004
Lancaster, Pennsylvania
yo quick question, what is the bottom hose that attaches to the intake pipe. I know the top one is the valve breather, but where does the bottom one lead to and what does it do? :confused:
There should be three nipples on the intake pipe. The biggest one goes to the charcoal canister under your battery, the middle sized one goes to the valve cover, and the really small one goes to your bcs which is on the pannel under your filter
-Steve
-Steve
Let's not forget the extra large one for the BOV. :p
what does that charcoal canister under the battery do? why is there a hose that goes to the filter for that?
no its still there i just wondered what the point of it was, b/c aftermarket intakes dont have that they just have the hole for the dump tube off the BOV.
sccrAdidas15 said:
Use good forum etiquette as much as possible - especially in our Tech Forums.
When posting in the forums:
Be friendly and helpful at all times. No elitist or negative attitudes.
Use the Spell Check feature and proper grammar. Don't be lazy, type out the whole word and use capitalization. No web-speak!
Fill in your profile completely, including your Name, City, State and vehicle info.
Do not post info found in our forums on other website forums.
Avoid using vulgarities, or at least keep them to a minimum.
Respect our Signature Policy and Gallery Rules.
No bumping threads (replying to your thread for the sole purpose of moving it to the top of the forum for more exposure). If your question doesn't get answered, it's either because you didn't provide enough info, your profile isn't filled in, or you asked a question that was already answered in our FAQ forum.
When linking to images that are not hosted here on DSMtuners (like ImageStation for example), if they are larger than 700 pixels wide, please just post a link to it. Do not use the BB IMG code to make it display inline, use the BB URL code instead. Why you ask? Page load times and display reasons. Large images cause slow load times and cause the page to be displayed funny for most people. If the moderators come across large images, they will likely replace them with a hyperlink for faster page loads and better page displays. Attachment uploads (which are hosted on our server) are limited to 700 pixels.
Please do not bump your thread again.
