horray, im an idiot!
Bojangles465
194
Sep 6, 2012
athens, Alabama
so ive been having alot of issues out of my car with idle, so i adjusted the tps,biss, and ips, and it didnt work... or so i thought... apparently i just didnt let the car run long enough, because i just cranked it up, and the ecu relearned everything:ohdamn:, and is idling steady at 800:thumb:, im fixing to take it for its first test run, and it should be good!:hellyeah:
adjusting the biss by itself isn't how it works. The ISC is constantly controlling air. The biss adjustments just allows the ISC to have it's maximum range as you set eveyrthing up for the ISC to be in the middle of it's range at idle. You've already been given the proper procedures to do this. There is no learning involved. Set it right and it's there immediately. You still may not have it right if you did not follow the instructions.
