hooking up screen
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
hey i got my eclipse dvd slip screen in the dash. i also have a screen in the trunk that isnt hooked up. how would i go about hooking that screen up. the brain for the eclipse flip screen is under my seat. im sure id have to run some cables from there to the screen in the trunk right.. someone help me out man!!! :confused:
youd have to run wires as u did your dash one but just longer ones. if you are looking for a hookup u can splice from your dash one. remove your seats and run it through the wire through the center councle and under the carpet into the trunk. you can find wire kits for DVD players at any Audio/video place. ebay is a god way to go.
how do you want to run your audio? trough subs n amps directly on its own port or split off the main head unit? if directly off its own port you need a seperate audio system if off the same port you just use audio cable spiters and attach em with the main head unit but youll probably get a cramped wire mess under the dash.
