Holset Turbine wheel diameters
Streetsweeper21
140
Jan 11, 2006
Atlana, Georgia
Whatz up Tuners? Im trying to figure out if a 2.4" / 63.04mm Turbine Wheel Diameter off a Holset Wh1E will fit in the BEP 70 a.r Housing? I dont want to get the wrong Holset any help well appreciated....!THANKS
Matt can maybe verify this as I've not had much experience with the older H1 turbos, but I believe the H1E uses the same turbine as a HX40....in which case you'd want the Bullseye T3 turbine housing that is made for the HX40.
