Holset Hx35 8cm^2
You would need a different manifold and o2 housing for it to work, but it is less restrictive then the dsm BEP bolt on housing. You should be able to hit your goal with either housing, t3 or dsm. Not familar with a 8cm housing as jusmx said, from my knowledge stock ones varied between 12cm and 21cm.
