hole in the fire wall
Scott_S
182
4
Feb 17, 2006
Austin, Minnesota
Were is the best place to either drill a hole or utilize an existing hole in the firewall? I need to pass my ebc connector through and also a few vacuum lines from some gauges. Thanks for any help
On the passenger side of the firewall, there is a large wiring harness that passes through under the dash. You may need to pull back some carpeting to see it. The wire bundle will pass through a rubber grommet. Here is a picture from the fuel pump re-wire vfaq to help you locate it:
From the engine side, it should be beneath the battery tray.
Ok, I tired today and that hole is to small to get the connector though, so plan B?
