Hole in my radiator
ZDA1728
95
Dec 13, 2012
Chicago, Illinois
I poked a hole in my radiator like an idiot. Luckily it's not too big and its on the metal core. A new radiator really isn't an option right now as I don't have the funds for it. What I wanted to ask is what are my best options? I've heard VERY mixed reviews on radiator epoxy, but my only two options is radiator epoxy or JB weld. I wanted to get input from people who have plugged up fairly small holes in their radiators and what worked best for them. Thanks :thumb:
ZDA1728. I have used jb weld and 60 sec epoxy before on two of my radiators on my other cars with success. Just make sure you let the mixture cure like the directions say before running your car again. This is a temporary fix mind you so replace the radiator whenever possible. Good luck.
I think I'm gonna try jb weld as I can let it dry properly for at least 3-4 days while I wait on my parts
^ even cheaper than that if you go to a junkyard, pull one, and have it pressure tested.
Radiators-hot-cold-hot-cold
Epoxy will never hold even if its only 18psi max
