HKS carbon ti catback with apexi DP??
What cat are you using? They bolt to the cat, not to eachother. And I thought you had an exhaust... :confused:
i am not going to have a cat i was gonna cut the ends and weld it,will it work
yea i know i have an exhaust already but i always wanted the carbon ti one and i got a good deal on it
this has been discussed already...
Apexi and RS*R downpipes are meant to fit the same brand cat-backs. When you buy an Apexi or RS*R catback, it comes with an adapter to bolt to the stock cat. The downpipes are therefore longer, eliminate the cat, and eliminate the need for the adapter.
If you've got another brand cat-back, the downpipe will be too long (unless for some reason it comes with an adapter like the Apexi and RS*R).
yea but cant i just cut it and weld it how can i make the hks work w/ the apexi dp, their has to be a way
yeah, what I was saying is that it won't just bolt on. you'll have to cut a section off of the downpipe and then weld the two pieces back together.
