HKS BOV flanged 2g UICP?
fergulus
205
Dec 18, 2007
Portsmouth, UK, Europe
I am looking for 2g upper intercooler piping that is 2.5" and is flanged for the HKS SSQV BOV. I have looked and can only find 2.25" UICP. I am going to install the Magnus Street SMIM, and my current UICP will not work, as it was gentle bends that will hit the battery upon install.
Does anyone know of a good place to find this part? :hmm:
You might want to look into relocating the battery. It's an option.
Another option would be a universal kit that you mock up to fit. Then take it to a welder and have them put a HKS flange on it at the same time they weld the pipes together.
If you want a 2.5" intercooler pipe i would suggest you custom-make one yourself and weld in a universal hks flange.
I got the small battery kit from JM fab so that I would have more room, but i'm still worried that I wont have enough room. I've seen Dejon UICP that has a sharper angle than my current setup (installed when I got the car) but was only 2.25." I'm trying to get a full 2.5" piping all the way to the TB.
My real issue for starting this thread was to find 2.5" UICP that had the proper angle for the SMIM. Dejontool has this, as well as a 2.25" UICP that will work. it is the "UIP-2gD" setup. You will need to tell them it is for a sheet metal intake so they can change the angle of the flange. You will also need to have them take one inch (1") off the pipe that connects to your lower intercooler piping (or your stock intercooler). This is what I am currently running on my car in long route setup, and it looks perfect. If you check out their website, you can also see that they will flange it for any BOV you can want.
  • Wanted 6 bolt NT water pipe
    • chrisman287
