High vac reading.....
gsxrtalon
395
Apr 23, 2005
Harrison, Michigan
I have noticed that my vac reading at idle is staying at -23 to -23.8 or so and my idle is at 700-900rpms. Is my vac reading really high? Isnt it supposed to be -19? Sometimes Ill start my car recently and it will fire right up then after a minute the idle will drop real low and it will die, once the car runs for a couple minutes or so the idle is fine. Any thoughts as to why my car does this. ISC? TPS? Plugs?
If you think your low idle is causing it, then adjust the BISS screw and turn your idle up some.
I am having the same problem with vac. mine reads 29@ 800rpm! high right ? When you find out what causes yours let me know. No trouble with stalling though, thank god. Good luck man.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
