1G High idle problem
RockyMtDSM
Aug 4, 2021
Gunnison, Colorado
Hey guys I just rebuild the head on my 4g63t 95 GSX and I have an idle problem! I have adjusted my biss screw many times with no luck. When I first start her up she idles perfectly then when she warms up it can go all the way up to 3k! Has anyone else experienced this?
Yes I replaced all the gaskets. The only test I haven’t done yet is a boost leak test. I’m trying to build a way to put pressure back through the system without harming it. I guess I should have waited to post about this till I get that done. In my mind everything points to a boost leak.
Let us know what you find. I have a 20 year old Home Depot custom BLT. I’m sure there are some more modern YT videos on how to build one yourself if you want to do that.
