high fuel pressure after 255 install
bjmauck
203
Feb 20, 2009
Augusta, Georgia
Trying to tune after my walbro 255 and 1000cc injectors and my fuel press is 60 psi. I have a fuel lab afpr and turn the screw one way it goes up and the other makes no difference.screwed the screw almost all the way out and still 60 psi. I had a 190 installed with it set at 43psi and no issues. The pump was for a mustang and the screen was made different but I figured a walbro 255 should be the same. Any suggestions?
I don't know if this helps but you have to take off the vac line and cap it with your finger to set base fuel pressure. I am about to install my fuel lab fpr tonight. I have a rewired evo 8 fuel pump.
