High beam indicator lamp doesn't work? (the headlights are fine)
DaJackal
89
Jun 11, 2009
Lappeenranta, Europe
Hi guys,
It's my '95 N/T Eclipse giving me trouble again... this time with the lights.
When I switch to high beams, the high beams light up and work fine, but the blue indicator lamp stays off. Already checked:
-Dedicated fuse nr.7
-The indicator bulb itself is ok (I diagnosed that the connector pins behind gauge don't get any voltage, so the problem is somewhere between the fuse and gauges)
What to check next? Could it be the headlight relay or what?
