HID Lights
timsturbotalon
115
Nov 19, 2008
blacksburg, Virginia
I bought the hid kit for low beam. Now i am wondering if you can use the same ballast for the high beam if you use the harness behind the headlights. This is for 2g eclipse
You must have a seperate ballast for each individual headlight that you intend on running high intensity discharge with. Or are you asking in regards to using the low beam ballasts and putting them in for high beam?
want to use one ballast for low and high. theres a plug the goes into the rear of headlight assembly that powers both low and high beam. will one ballast work?
u have to run a seperate ballast and a relay for the highbeams.. ask sharphid they have both things with instructions so you wont burn a wire
I never seen HID lights on a 90-91 dsm? take pictures when you finish.
