90laserRSfwd
- 1,411
- 86
- Mar 5, 2007
Elizabethtown,
Pennsylvania
good luck, with the 3 bolt and sourcing a 4 bolt. For some reason I can't seem to find a 4 bolt for my car
I believe all 2gs had a 4 bolt rear end so there would be no need to swap unless you where doing a auto to manual swap. Can anyone conform this?
probably easier to pull the other side then just punch it out from the middle.I'd probably drill, tap & 'jack" it out..
& Gee the 3 BOLTS didn't actually break - Would a 4 Bolt have been any better here?
knock on wood but i have launched my car SEVERAL times at 6k studder box launches and still have not broken a 3 bolt. my car has over 170k on it now. i dunno what you guys are doing but it must be pretty sick!
Do you still have stock springs? As I said above (somewhere) I had no probs with the rear axles until I changed out the springs to the H&Rs. The extra travel combined with your stiffer shocks must be helping youi ushally have good luck with these cars. once again knocking on wood but i have NEVER even changed my rear diff fluid...
SWEET!!!!!!!or just maybe....
Nvisabl
Car: 91 Talon TSi AWD
Dyno: 578.1whp/447.9 lb-ft
Region: Mid Atlantic
Trader Rating: (0)
Quote:
Originally Posted by JayRolla View Post
I dont agree, mechanic has seen this type of break over 10 times all replaced. Center section was not damaged on any of the diffs. He runs jackstransmissions.com so he has seen his share of 3 bolt rear shaft failures.
I have broke 5 personally and all 5 looked just like that and all 3 destroyed center section. It was said and I didn't disagree try an axle. Worst it can do is cost you $60.00
Ofcourse you can always test the rear end to see.
Goodluck
..... I might know a little something about these cars
____________________________
D.J.
