Help With Tachometer
On your '99 the stock tach signal comes from pin 4 (white wire) of the power transistor connector. It also goes to the ECU pin 58 (white) and the dash gauges connector pin 24 (white). The 2 other wires go to +12V ignition switch and ground.
So I can pick from one of those or no.
