help with rough idle, bad fuel trims. o2 sensor???
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
my Car has recently began to idle a little rough and bog out on hot starts. i ensured the FPR solenoid was hooked up. When i hook my logger up, the o2 voltage is stuck at .08 and the o2 trim is at 100 percent. My fuel trims are all 3 stuck at 138 and barely move. My idle sounds like its missing. The car idles this way with or without the o2 sensor plugged in. Could this be a bad o2 sensor??
Also when I listen closely to the FPR solenoid I can hear air, I cant tell if its a leak or the vacuum traveling through. Anyone shed light on this?
Thanks in advance
Completely different topic, what o2 housing is this
If the front o2 sensor isn't cycling after the cars warmed up then the ECU will lock itself in open loop and idle like ass. That is a 2g o2 sensor housing, a better question is what brand of o2 sensor is that?
:dsm:
yeah it idles wierd. would the fuel trims look lean because they are pulling fuel trying to correct a rich mixture. I dont know what o2 sensor that is. bought the car with it
Its stuck at .08 which is LEAN so thats what the ECU is seeing ALL the time. I suggest getting a Denso o2 from o2sensors.com, they run sweet deals.
:dsm:
