Help with pistons
100shotofNOS
32
Jun 10, 2002
Alabama
My pistons just went bad and I dont want to buy the same stock ones I have.
Does anyone know if Arias pistons are as good as JE? I want something that has 9:1 compression
Why such high compression? I've heard of JE getting piston slap also. Ross can't handle as much horsepower (not like you will ever overrun their max anyways) but the JE have clearance issues. I would go with either 2G, EvoIII, or Ross. Maybe there's another I can't think of.
What compression should I run? That's what someone told me to get. I'm not sure what to get on these cars, I've had it for less than a week. I had a POS '97 RS. Do you know what the max HP is for Ross pistons?
i'm running wiseco's, just ran a compression test with 1750 miles on the new motor. 170 on all 4 cylinders. i had 178 with the stock (2g) pistons. no problems here, and only $399 w/rings & pins :)
Where can i get them for that price? My car jumped time & 2 of my pistons have to be replaced, so I need to find some soon
ROSS I would do a .20 or .30 boar and hone them btw if i were you and get them in 8.5:1 compression thats safer than 9:1 i dont know but a handfull up ppl with 9:1 but most use 8.5:1 on 1G's
btw if you lost two pistons becouse of the valves you just kissed the valves for thoughs cyl good bye too... so mid as well replace them all with some SS polished ones brass guides titanium retainers and better springs.. tehn you can rev higher too.. although if you dont have the green backs to do this then just replace and enjoy stock again...
Are the SS valves a lot stronger than stock valves? I had to take my NOS kit off of myother car because it was taking bi chunks out of them.
2 of the valves in there now are bent
I'm changin' my pistons, too... I'm goin' with Ross. Another question for you guys, though. What about the crank? Leave it stock, or rework it? Is it ok to use the stock rods & bearings?
'92 converted N/A to Turbo
Yeah, and your driving a what:confused:
I'm also going to be using Ross pistons, should be getting them today from the UPS truck along with my other goodies from Slowboy Racing. Evo III manifold, HKS springs, ACT 2600 clutch, 550cc injectors, poly mounts, 255 fuel pump. And next week I'm ordering the Evo Big16G from them. Can't wait till the cars done. Also bought a VPC, and AFC.
ok guys for 2g on 90 laser fwd turbo, are the direct replacement? just rings and pistons?
  • Wanted 2g Front Mudflap Set
    I am looking for a set of front 2gb mudflaps. Will pay a fair price plus shipping to 14216. I...
    • EclipseDSM59
  • For sale 1g 1993 Eagle Talon TSI AWD
    1993 Eagle Talon TSI AWD $9,500- Clean Title in Hand ( in my name ) - 95,600 miles ( 3,600 on...
  • For sale 4G63 1G OEM Knock sensor
    1G OEM Knock sensor Came off a running car$85usd shipped Lower 48/Canada
    • Dsm_canadian_mike
  • For sale 4G63 Waterline sets with bolts
    Water line sets. 45 deg and 90 deg in each pair. With banjo bolts. . Have ten sets like this...
  • For sale 4G63 1g cy head with 2g intake ports
    1g style cy head. Bigger end studs on exhaust port. 1g Waterneck. 2g intake ports. Great cy...
