help with my rebuild
slick06emp
53
Apr 28, 2009
Lawrenceville, Pennsylvania
im shooting for 350-400 daily driver. so far im looking at
mahley forged pistons
eagle hbeam rods,
arp's,
clevite tri metal main and rod bearings
oem oil pump or topline
topline freeze plugs
fel pro complete gasket set
being my block is the one thats prone to crank walk <- hate that word...
does anyone have any suggestions as to preventative maintenence. i do plan on reusing my crank as long as it checks out ok. ive read that some poeple eliminate the oil squirters, is that a good idea? what about my thrust bearing, this is going to be my first build so any input or suggestions would be great. thanks
i wouldnt you can never have enough lube... i would do a nice rebuild def if you want 400whp go one the tech section they have upgrade paths that will help you alot
What do you have for a turbo set up and fuel? I would just make sure to measure the crank end play and make sure its within spec and don't go too crazy on a clutch..
