Help with my driver parking light...
99dsmturbo
80
Jun 19, 2006
Manitowoc area, Wisconsin
An issue just came up... I'm not sure what's wrong... when i turn my lights on, my outside driver side parking light wont turn on, but inside cluster left signal turns on and stays on. when I signal to the left it blink fast. everything on the right side is fine. feels like somewhat my parking and cluster left signal is swap around. Help anyone.
First, check you light bulb and the connection to the bulb. Make sure there is no corrosion on anything. Swap the light buld with the other side and then see what it does. The problems is most likely just the bulb.
A bulb flashing faster than normal is usuall indicative of a blown bulb. Are you sure you dont have a bulb out? Is the wiring ging to that bulb frayed, or shorted?
