Driver Side Parking light/turn singal problem
gijeff1805
Jan 26, 2004
conyers, Georgia
Ive done some searching and can't really seem like ive found my problem. My driver side parking light does not turn on whenever u turn on ur parkin lights or headlights. the running light lights up but not the parking light. On my dash the turn signal arrow stays green sayin something is wrong and when i turn the left signal on it blinks but it blinks really fast. Ive tested the socket for power and its gettin power. i dont know what it is, its odd cuz the parkin lot was workin and all the sudden it stopped, ive checked all bulbs and replaced them with correct ones. Anyone know what can cause the parking light to stop working and make the blinker blink faster? it is just the front driver side parking light, all other lights work fine.
Maybe you have a light bulb that's burnt out. You can get a new light bulb and try that. Some go for a new bulb carriage as well (the holder for the bulb) because the stock ones aren't that good I hear.
Usually the only time it does this is either when your lightbulb is dead or you have a loose wire to a lightbulb somewhere. Something to that extent. Just double check all your bulbs again and then start checking wiring to those bulbs. That's all I can tell ya unfortunately.
I checked the wires coming of the parking lot and tested the harness and socket...its gettin the constant and break in power for when it blinks. All bulbs on the outside of the car on the driver side are the only bulbs which could trigger the computer to say something is wrong, and those are all fine. So i think we just might have come across a problem noone knows how to fix, unless its just the flasher which i might replace to just see, though i doubt it is that cuase the light does flash just it doesnt stay constantly on like it should when lights are turned on.
