420A Help with fault code p0300
Cris420A96
Mar 14, 2026
New York
Buenas amigos ocupo de su ayuda tengo un mitsubishi eclipse 96 motor 420A stock original no es turbo mi problema es que tengo el código p0300 ya hice cambio de lo más común ala falla (sensor de cigüeñal, sensor árbol de levas,bobina,cables de bujías,bujias ya se reviso fugas de bacio y nada sigue apreciendo)se borra mediante el escaner y derrepente en el transcurso conduciendo aparece y empieza a parpadear y lo hace como dos veces el parpadeo se vuelve a escanear y se borra necesito de su ayuda qué podría ser un consejo de lo que hay que hacer ...
Google Translate:
Hello friends, I need your help. I have a 1996 Mitsubishi Eclipse with a stock 420A engine (not turbo). My problem is that I have code P0300.
I've already replaced the most common parts (crankshaft sensor, camshaft sensor, ignition coil, spark plug wires, spark plugs). I've also checked for vacuum leaks, but nothing has worked; the code keeps appearing. It clears with a scanner, but then suddenly reappears while driving and starts flashing. It flashes about twice, then I scan it again, and it clears.
I need your help; what could be the problem? Any advice on what to do?
Try the fuel filter next and run fuel system cleaner with the new filter. It might also be good to remove and clean the injectors themselves to make sure they have a good spray pattern
The other replaceable item would be the front primary oxygen sensor, or even cleaning the knock sensor or the wiring to the sensor
If you have a good obd2 scanner it may be possible to measure the misfires per cylinder in the live data readings, but I’m unsure of how advanced the scanner would be with these cars.
