help with air fuel gauge?
joshrww
56
Mar 6, 2010
conway, Arkansas
ok so i went and got a few gauges got all of them hooked in but the air fuel mix gauge. i know it goes on my o2 sensor but i have a 4 wire sensor and im not sure witch on it goes to the sensor has 2 black 1 white and 1 blue and in the book that came with it said to contact the maker.. anyone ever hooked one of these things up ?
Did you buy the narrow band A/F gauge that just shows lights bouncing back and forth or an actual wideband o2 sensor for accurate readings?
If you bought a wideband, there would have to be a new o2 sensor that you screw into a bung that would be welded into the exhaust header
ok so i just took that out of my car and will return it today ... i also just got that "http://cgi.ebay.com/ebaymotors/Innov...Q5fAccessories" that liquid suggested thanks. what else gauges should i get ?
All you really need is a good boost gauge (something that has a higher PSI than you will run) and the wideband for tuning purposes.
here is a pic of my boost gauge is it ok ? it works well atm says im runing 13psi and the car is stock.. and no boost creep.
and i dont plan on running more then 20 psi. if even that
SunPro should be fine. Other users have used it. I started with an autometer 30-20 gauge and should have just gotten teh 30psi gauge from the start even thinking I wouldn't go higher than 20psi. Now I have an Autometer Cobalt -30 inHg - 45psi.
If you want a clean factory looking install for the 2 gauges
http://www.streettunedmotorsports.com/parts/dual_gauge_bezel_2g_dsm.htm
