help with 1g 1st log
1gfwd16g
30
May 26, 2004
moore, Oklahoma
ok a couple questions first
1. are my fuel trims supposed to ever move? (mine never move at al and are always at 100)
2. I have a cel#13 which is intake sensor temp.( i have a maft blow thru setup. i need to know which wire is for this on the GM mafs and where it leads to so i can make sure its connected.
RPM PulseWidth KNck o2 INJDTY TIMA
4500 15.10ms 35 .89 56.2 17
4843 14.84 34 .89 59 10
5281 15.10 32 .89 66.4 13
5781 14.33 38 .89 68.7 14
6218 14.07 42 .89 72.6 14
6343 13.82 42 .87 72.6 14
3rd gear WOT TPS 99.6%
http://www.cardomain.com/id/1gfwd16g mods here
anything else u need just ask.
Might just be phantom knock. Looks like you have the mods to support it. You might need to get a FPR as well with the 255. What kind of gas are you using in it? Hope its not 89. Also what program are you using to log with? It should not jump 300 rpm's everytime your logging. And you need to get that sensor working b/c since you have a CEL your car is in open loop mode which will cause the trims not to move. If you get that fixed then they should move and in return will make the car easier to tune.
