Help w/ turbo.
Ok, does it matter if I used the factory oil feed location or should I use the one on the side of the head? Will I be getting to much oil pressure if it’s in the factory oil feed? Will it matter or should I just leave it how I have it?
Ok well I ran into another problem I decided to tap my oil feed line to the side of the head. Now I'm not getting any oil pressure. I tried unscrewing the banjo bolt for the oil feed line to see if i was gettin oil to the turbo before i started the car and I got NOTHING. I tried several times. I also tried it from the stock oil feed location and nothing. WHat do you all suppose can cause this. Thats the only thing holding me back right now, once i get that figured out she will be ready to drive.
