Turbo help!!!
Brad_95_GSX
Sep 7, 2003
Traverse City, Michigan
I have a 95 GSX. My stock turbo is pretty mcuh gone so I think I am going to upgrade to a 16G Evo III, I know that I need a install kit, and boost controller, but do I need the aftermarket blow off valve, injectors, and fuel pump right a way? the only mods I have to my car right now are K&N filtercharger, and 2.25" exhaust from the downpipe back. If you could please give me some help. Thanks
If you want to run more boost than stock, you will need a BOV and boost controller. If that doesn't matter, you don't NEED that stuff, and the new turbo would be just fine. But i would say just spend the extra little bit of for a 1g bov and mbc, and enjoy your new turbo right away. Just be careful not to crank up the boost too much, not on the stock fuel system. I run 15-16 on stock fuel and my T25 for about 6000 mi. now. Should be safe with that.
