Help Trans temp sensor
Darkolako
31
Feb 21, 2010
bayamon, Puerto Rico
ok guys I have been trying to install a few gauges myself but I am a complete noob on this, thanx to members from here i figure out the boost gauge installation since my car doesn't have the fuel pressure solenoid
Now my question is about the Trans Temp sensor where exactly do i install it, i have searched around and found some pages that say to attach it on the drain plug or to drill the pan , is there a way i can do this installation without draining my trans oil or working on the pan.
I found something about installing it on a return line from the cooler, can anyone please explain this process in details I cant find a guide for this method anywhere, pics would be awesome i would like to know exactly where to work and if i need any extra parts etc
and to avoid making another thread if you can help me with the oil sender for the oil pressure gauge, i tried removing the original but the one i got from glowshift the thread is a bit bigger and doesn't fit, i would like to do it without buying that $40 filter sandwich adapter if possible.
again sorry for bothering so much and for my english.
details.
Do you have a picture of the sensor for the transmission temperature gauge. I know the lines for a trans cooler are pretty small and not able to be tapped.
As for the oil sensor, a little ingenuity and random fittings from eBay will allow you to resolve this issue. I don't have any pics of a rig a friend of mine did, but it worked. However, he spent close to the same amount I spent on my sandwich.
