2G Help - removing Trans end case
miliman13
2,436
648
Jan 1, 2011
tampa, Florida
I am having a very hard time removing the end case.
Theres a small crack on it and it’s not easy to get to, so that is why I am removing the case.
I watched a few videos, some like Jafro used straight blades to accomplish this but I cannot get them In there at all from any corner.
I have tapped on it with a hammer and tried using a flat head to pry it but I’m afraid if I try any harder I’m going to make this worst.
Please advice
Thank you.
Yes sir I was prying right there, but my flat head just bends, I’m scared of applying to much force.
Looks like somebody already had. There is a lip around the drain plug. Looks like some of it is broken off. Not a big deal. I can't remember if the lip is on the end case or the bearing plate. Either way you can use this as leverage.
Put the drain plug back in, pry under the drain plug between the bearing plate and the drain plug. It pops off 5th gear cover with ease. Make sure you have all 9x of the medium length bolts and 2x long bolts out also.
Thanks all - unfortunately wasn’t able to
No budge, can’t get the thinnest straight blade in there, just gonna have to try and weld the crack while still in trans.
I used a slide hammer hooked In the drain hole don’t work - I just stopped I’m confident I will just brake it.
It literally has two tiny alignment dowels holding it on, and RTV sealant. I take these apart every day with a small prybar between the drain plug and the case. You are certain you have all of the bolts out??
  • Wanted 1g Headliner
    ISO 1G Headliner with sunroof provision
    • ItsTwan309
  • Wanted 2g Rear Evo8/9 calipers
    Looking for a clean pair of evo 8/9 rear calipers.
    • Schinjon
  • For sale 2g turbo ecu’s
    $120 each +shipping&pp fees.
    • Fully built dsm
  • For sale 650cc injectors
    Fic 650cc injectors $70 plus shipping and pp fees
    • Fully built dsm
  • For sale 2g dsm link v3
    Hello, It works great I just took it off because I’m selling the car stock and don’t have any...
    • Fully built dsm
